Bracing???
3.4K views 15 replies 7 participants last post by  red69hoss
#1 · (Edited)
As so me of you have read I am well into tearing down my 69 convertable. I am about ready to remove the entire dash now. I have told that the car needs to have braces welded in during restoation. Can any one shed some light on this? I am not planning to remove the fenders, doors, or engine.
#2 ·
If your car has structural rust issues, then yes. Braces in the door jambs is necessary. if the car is structuraly sound, then no worries.
#5 ·
By sound, that is the inner and outer rockers. The braces in the door frame are to support the front and back half of the car while the rockers are replaced.
#7 ·
The metal that runs below the door.
#9 ·
Might also be talking about stiffening the unit-body with sub-frame connectors, export brace, monte carlo bar? Cheap and easy, makes the body much stiffer and the car handle better.
#10 ·
Summitt sells a stiffener for Cougar's and Mustang's.
I put a Monte Carlo bar on mine, but I've only seen one other Cougar with one.
#11 ·
My sub-frame connectors are Global West but I think several other vendors offer both bolt-on and weld-on.
I like Monte Carlo bars. Surprised more Cougar people don't use 'em. I'm not sure exactly how much they stiffen the engine compartment but, hey, sometimes chrome is an end in itself....
#14 ·
I agree. I think you should stiffen ALL unit-body cars, regardless of whether you're specifically building a high-horsepower and/or flat-handling car. Its cheap and it makes the car safer. There's no reason not to do it unless you have a concours show car or something.
'69cugr, I like the curved monte carlo bars because I like the way they look with the oval air cleaners. There are pics on my website of the engine compartments of both my 67 Cougar GT and dearly-departed '69 Mach 1....
